Datasheet Texas Instruments TS5A3359YZPRB — Даташит
СерияTS5A3359
МодельTS5A3359YZPRB
Аналоговый переключатель SP3T, 1 Ом, 5 В/3,3 В, одноканальный мультиплексор/демультиплексор 3:1, 8-DSBGA
TS5A3359 1-О© SP3T Bidirectional Analog Switch 5-V/3.3-V Single-Channel 3:1 Multiplexer and Demultiplexer datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 25 янв 2016
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
МаркировкаJ97
Width (мм)2.25
Length (мм)1.25
Thickness (мм).31
Pitch (мм).5
Max Height (мм).5
Additional FeaturesPowered off protection,Break-before-make
Полоса частот75 МГц
Bandwidth(Max)75 МГц
Configuration3:1
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)200 мА
Input/Output OFF-state Capacitance(Typ)18 пФ
Input/Output ON-state Capacitance(Typ)78 пФ
Количество каналов1
OFF-state leakage current(Max)0.25 мкА
ON-state leakage current(Max)0.22 мкА
Package GroupDSBGA
Ron(Max)3.5 Ohms
Ron(Typ)0.7 Ohms
Supply Current(Max)1 uA
Supply Current(Typ)0.01 uA
Supply Range5.5 Max
VIH(Min)1.5 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
RoHSНе совместим
  • Using ADS8411 in a Multiplexed Analog Input Application (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 15 фев 2006
    This application report is intended as a guide for using an analog multiplexer to multiplex several input signals to a single high-resolution, high-speed SAR analog-to-digital converter (ADC). The ADC and the multiplexer used were the ADS8411 and the TS5A3159/3359, respectively. This document discusses the important parameters of a multiplexer and defines a few important measurements for evaluatin
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
На английском языке: Datasheet Texas Instruments TS5A3359YZPRB
