Datasheet Texas Instruments V62/04708-01XE — Даташит
СерияSN74LVTH162244-EP
МодельV62/04708-01XE
Усовершенствованный продукт 3.3.-V Около 16-битных буферов/драйверов с выходами с 3 состояниями 48-TSSOP от -40 до 85
SN74LVTH162244-EP datasheet
PDF, 292 Кб, Файл опубликован: 10 ноя 2003
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH162244EP
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
Тип входаTTL/CMOS
Тип выходаLVTTL
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVTH162244-EP (2)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
V62/0470801XE, V62/04708 01XE
На английском языке: Datasheet Texas Instruments V62/04708-01XE
Публикации по теме
