Datasheet Texas Instruments 74CBTLV3126DBQRE4 — Даташит
СерияSN74CBTLV3126
Модель74CBTLV3126DBQRE4
Низковольтный четырехместный переключатель шины на полевых транзисторах 16-SSOP от -40 до 85
SN74CBTLV3126 datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 10 окт 2003
Pin16
Package TypeDBQ
Industry STD TermSSOP
Package QTY2500
МаркировкаCL126
Width (мм)3.9
Length (мм)4.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Additional FeaturesPowered off protection
Полоса частот200 МГц
Configuration1:1 SPST
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)7 пФ
Input/Output ON-state Capacitance(Typ)2.5 пФ
Количество каналов4
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Ron(Max)40 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)20 uA
Supply Range3.6 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
На английском языке: Datasheet Texas Instruments 74CBTLV3126DBQRE4
