Datasheet Texas Instruments SN74LVC1G132DCKR — Даташит
| Серия | SN74LVC1G132 |
| Модель | SN74LVC1G132DCKR |
Один вентиль И-НЕ с 2 входами и входом триггера Шмитта 5-SC70 от -40 до 125
SN74LVC1G132 Single 2-Input NAND Gate With Schmitt-Trigger Inputs datasheet
PDF, 889 Кб, Версия: D, Файл опубликован: 8 июн 2017
Купить SN74LVC1G132DCKR на РадиоЛоцман.Цены — от 2.83 до 470 ₽57 предложений от 22 поставщиков Интегральные микросхемы Логические микросхемы - Затворы и Инверторы | |||
| SN74LVC1G132DCKR Texas Instruments | от 11 ₽ | ||
| SN74LVC1G132DCKR Texas Instruments | 32 ₽ | ||
| SN74LVC1G132DCKR Texas Instruments | по запросу | ||
| Pin | 5 | 5 |
| Package Type | DCK | DCK |
| Industry STD Term | SOT-SC70 | SOT-SC70 |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 3000 | 3000 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | D5R | D55 |
| Width (мм) | 1.25 | 1.25 |
| Length (мм) | 2 | 2 |
| Thickness (мм) | .9 | .9 |
| Pitch (мм) | .65 | .65 |
| Max Height (мм) | 1.1 | 1.1 |
| 3-State Output | No |
| Bits | 1 |
| F @ Nom Voltage(Max) | 150 Mhz |
| Gate Type | NAND |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Logic | True |
| Output Drive (IOL/IOH)(Max) | 32/-32 мА |
| Package Group | SC70 |
| Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
| Rating | Catalog |
| Schmitt Trigger | Yes |
| Special Features | Ioff,down translation to Vcc,low power,Schmitt-trigger |
| Sub-Family | NAND Gate |
| Technology Family | LVC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,3.3,5 В |
| tpd @ Nom Voltage(Max) | 16,7.5,6,5 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G132 (9)
- Semiconductors > Logic > Little Logic
