Datasheet Texas Instruments TPA3251D2DDVR — Даташит
СерияTPA3251
МодельTPA3251D2DDVR
175 Вт стерео/350 Вт моно Ultra-HD, аналоговый входной усилитель класса D 44-HTSSOP от 0 до 70
TPA3251 175-W Stereo, 350-W Mono PurePathв„ў Ultra-HD Analog-Input Class-D Amplifier datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 20 апр 2016
Pin44
Package TypeDDV
Industry STD TermHTSSOP
Package QTY2000
Маркировка3251
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).635
Max Height (мм)1.2
Audio Input TypeAnalog
Control InterfaceHardware
Выходная мощность175 W
Power Stage Supply(Max)36 В
Power Stage Supply(Min)12 В
Power to Bridge Tied Load(Max)220 W
Power to Parallel Bridge Tied Load(Max)355 W
SNR111 дБ
Speaker Channels4 Max
THD + N @ 1 kHz0.005 %
  • Evaluation Modules & Boards: TPA3251D2EVM
    TPA3251 175W Stereo / 350W Mono Ultra-HD Analog-In Audio Class-D Module
  • Evaluation Modules & Boards: SIDEGIG-GUITAREVM
    Guitar SideGig Plug-In Module
  • TPA324x and TPA325x Post-Filter Feedback
    TSP, Файл опубликован: 14 сен 2017
  • TPA3251 and TPA3255 Post-Filter Feedback (PFFB)
    PDF, 567 Кб, Файл опубликован: 28 июл 2016
    The TPA32xx Class-D audio amplifier family delivers tremendously high audio performance with less than 0.01% THD+N to clipping. The extremely high level of audio performance makes this device an ideal candidate for today’s high resolution and high fidelity audio applications where previously, only Class-AB amplifiers could deliver the performance.Since the TPA32xx family is an analog input close
  • TPA32xx Analog Input Grounding for Single Ended Inputs
    PDF, 79 Кб, Файл опубликован: 26 авг 2016
  • Multi-Device Configuration for TPA32xx Amplifiers
    PDF, 102 Кб, Файл опубликован: 27 сен 2017
    The TPA324x and TPA325x family of parts (TPA3244, TPA3245, TPA3250, TPA3251, and TPA3255)comes equipped with functionality to simplify systems with multiple Class-D amplifiers. Class-D amplifiersuse pulse-width modulation (PWM) switching (450 kHz – 600 kHz), which are discrete packets of energy,to deliver large amounts of power with very high efficiency. However, issues can arise if multiple
  • LC Filter Design (Rev. A)
    PDF, 1.6 Мб, Версия: A, Файл опубликован: 9 ноя 2016
  • Class-D Amplifier External Load Diagnostics
    PDF, 155 Кб, Файл опубликован: 23 янв 2017
    This application report provides design information for an external load diagnostics circuit to detect andidentify electrical faults between the output of an audio amplifier and a target speaker. While theTPA3111D1-Q1 class-D amplifier is used as an example in this application note, this design methodologyis relevant for most class-D amplifiers to provide external fault diagnostics.
Серия: TPA3251 (2)
  • Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > Analog Input Class-D
На английском языке: Datasheet Texas Instruments TPA3251D2DDVR
