Datasheet Texas Instruments SN74CBT3306PWLE — Даташит
| Серия | SN74CBT3306 |
| Модель | SN74CBT3306PWLE |
Переключатель шины на двух полевых транзисторах 8-TSSOP от -40 до 85
SN74CBT3306 datasheet
PDF, 1.0 Мб, Версия: H, Файл опубликован: 15 янв 2004
| SN74CBT3306PWLE Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 8 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 4.4 |
| Length (мм) | 3 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Additional Features | Low Power |
| Approx. Price (US$) | 0.17 | 1ku |
| Bandwidth(MHz) | 200 |
| Configuration | SPST |
| ICC(Max)(uA) | 3 |
| Input/Ouput Voltage(Max)(V) | 5.5 |
| Input/Output Continuous Current(Max)(mA) | 128 |
| Number of Channels(#) | 2 |
| Operating Temperature Range(C) | -40 to 85 |
| Package Group | TSSOP |
| Package Size: mm2:W x L (PKG) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) |
| Rating | Catalog |
| Ron(Max)(Ohms) | 12 |
| Ron(Typ)(Ohms) | 8 |
| VCC(Max)(V) | 5.5 |
| VCC(Min)(V) | 4 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBT3306 (11)
- Semiconductors > Switches and Multiplexers > Signal Switches > Digital Switch
