Datasheet Texas Instruments V62/04601-02UA — Даташит
СерияSN74LVTH16244A-EP
МодельV62/04601-02UA
Усовершенствованный продукт 3,3 В, около 16-битный буфер/драйвер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVTH16244A-EP datasheet
PDF, 707 Кб, Версия: F, Файл опубликован: 23 апр 2007
Enhanced Product 3.3-V Abt 16-Bit Buffer/Driver With 3-State Outputs 56-BGA MICROSTAR JUNIOR -40 to 85
V62/04601-02UA
V62/04601-02UA
Pin56
Package TypeZQL
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
МаркировкаLL244AEP
Width (мм)4.5
Length (мм)7
Thickness (мм).75
Max Height (мм)1
Bits(#)16
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 125
-40 to 85
-55 to 125
Тип выходаLVTTL
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L (PKG)56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR)
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)(V)3.6
VCC(Min)(V)2.7
Voltage(Nom)(V)3.3
RoHSНе совместим
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
V62/0460102UA, V62/04601 02UA
На английском языке: Datasheet Texas Instruments V62/04601-02UA
Публикации по теме
