Datasheet Texas Instruments CCB3T1G125QDCKRQ1 — Даташит
СерияSN74CB3T1G125-Q1
МодельCCB3T1G125QDCKRQ1
Автомобильный каталог Низковольтный коммутатор шины на одиночном полевом транзисторе 2,5 В/3,3 В с толерантным регулятором уровня 5 В 5-SC70 от -40 до 125
Single FET 2.5-V/3.3-V Low-Voltage Bus Switch with 5-V Tolerant Level . datasheet
PDF, 755 Кб, Файл опубликован: 21 июн 2011
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
Маркировка72R
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Additional FeaturesPowered off protection,Signal path Translation
Полоса частот100 МГц
Configuration1:1 SPST
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)5 пФ
Input/Output ON-state Capacitance(Typ)4 пФ
Количество каналов1
OFF-state leakage current(Max)10 мкА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingAutomotive
Ron(Max)10 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)20 uA
Supply Range3.6 Max
VIH(Min)1.7 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
Серия: SN74CB3T1G125-Q1 (1)
  • CCB3T1G125QDCKRQ1
На английском языке: Datasheet Texas Instruments CCB3T1G125QDCKRQ1
Публикации по теме
