Datasheet Texas Instruments ADS1243SJD — Даташит
СерияADS1243-HT
МодельADS1243SJD
Высокотемпературный 24-битный АЦП, 8 каналов, PGA 1:128, 50/60 Гц Notch 20-CDIP SB от -55 до 210
24-Bit Analog-to-Digital Converter. datasheet
PDF, 510 Кб, Файл опубликован: 19 дек 2011
Pin20
Package TypeJD
Industry STD TermCDIP SB
JEDEC CodeR-CDIP-T
Package QTY1
МаркировкаADS1243SJD
Width (мм)7.37
Length (мм)25.65
Thickness (мм)3.5
Pitch (мм)2.54
Max Height (мм)4.45
# Input Channels8
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.25 В
Digital Supply(Min)2.7 В
INL(Max)251.7 +/-LSB
InterfaceSPI
Рабочий диапазон температурот -55 до 210 C
Package GroupCDIP SB
Package Size: mm2:W x LSee datasheet (CDIP SB) PKG
Power Consumption(Typ)0.6 mW
Reference ModeExt
Разрешение24 Bits
Sample Rate (max)15SPS SPS
RoHSSee ti.com
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1243-HT (2)
  • Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
На английском языке: Datasheet Texas Instruments ADS1243SJD
Публикации по теме
