Datasheet Texas Instruments DRV8305NEPHPQ1 — Даташит
СерияDRV8305-Q1
МодельDRV8305NEPHPQ1
Автомобильный 3-фазный драйвер затвора BLDC с тремя токоизмерительными усилителями 48-HTQFP от -40 до 150
DRV8305-Q1 Three-Phase Automotive Smart Gate Driver With Three Integrated Current Shunt Amplifiers and Voltage Regulator datasheet
PDF, 1.9 Мб, Версия: C, Файл опубликован: 19 сен 2017
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY250
МаркировкаDRV8305NE
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Additional FeaturesSPI Management I/F
Control I/FPWM (6x/3x/1x)
Current Sense Amps3
Gate Drive1 A
Number of Half Bridges3
Рабочий диапазон температурот -40 до 125,-40 до 150 C
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
RatingAutomotive
Vs(Max)45 В
Vs(Min)4.4 В
  • Evaluation Modules & Boards: DRV8305-Q1EVM
    DRV8305-Q1 Automotive 3-Phase Motor Gate Driver Evaluation Module
  • Evaluation Modules & Boards: BOOSTXL-DRV8305EVM
    DRV8305N 3-Phase Motor Drive BoosterPack Evaluation Module
  • Understanding IDRIVE and TDRIVE in TI Motor Gate Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 11 май 2016
    The motor gate driver is an integrated circuit (IC) that primarily deals with enhancing external power MOSFETs to drive an electric motor. The gate driver acts as an intermediate stage between the logic-level control inputs and the power MOSFETs. The gate driver must be flexible enough to accommodate a wide variety of external MOSFETs and external system conditions.Texas Instrument’s IDRIVE
  • Sensored 3-Phase BLDC Motor Control Using MSP430
    PDF, 199 Кб, Файл опубликован: 20 июл 2011
    Brushless DC (BLDC) motors are electronically commutated motors that offer many advantages over brushed DC motors and, therefore, are becoming very popular industrially and commercially. This application report discusses a sensored 3-phase BLDC motor control solution using MSP430в„ў as the motor controller. Hall sensors are used to detect the rotor position and close the commutation loop. Both open
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Gate Drivers
На английском языке: Datasheet Texas Instruments DRV8305NEPHPQ1
Публикации по теме
