Datasheet Texas Instruments TS5A3157DCKRG4 — Даташит
СерияTS5A3157
МодельTS5A3157DCKRG4
Аналоговый переключатель SPDT 10 Ом 6-SC70 от -40 до 85
TS5A3157 10-Ω SPDT Analog Switch datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 15 май 2015
IC SWITCH SPDT SC70-6. 1 Circuit IC Switch 2:1 10Ohm SC-70-6. Interface - Analog Switches, Multiplexers, Demultiplexers
Рутоника
TS5A3157DCKRG4
8.45 ₽
TS5A3157DCKRG4
9.04 ₽
TS5A3157DCKRG4
36 ₽
TS5A3157DCKRG4
Pin666
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаJC5JCRJCF
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
Additional FeaturesBreak-before-make
Полоса частот300 МГц
Bandwidth(Max)300 МГц
Configuration2:1 SPDT
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)50 мА
Input/Output OFF-state Capacitance(Typ)5.5 пФ
Input/Output ON-state Capacitance(Typ)17.5 пФ
Количество каналов1
OFF-state leakage current(Max)0.2 мкА
ON-state leakage current(Max)0.2 мкА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Ron(Max)160 Ohms
Ron(Typ)5.5 Ohms
Supply Current(Max)0.1 uA
Supply Range5.5 Max
VIH(Min)vcc*.7 В
VIL(Max)vcc*.3 В
Vdd(Max)5.5 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A3157 (6)
На английском языке: Datasheet Texas Instruments TS5A3157DCKRG4
