Datasheet Texas Instruments TS3DDR32611ZQCR — Даташит
СерияTS3DDR32611
МодельTS3DDR32611ZQCR
1A Пиковый приемник/источник PCDDR3 Оконечный стабилизатор 48-BGA MICROSTAR JUNIOR
1A Peak Sink/Source PCDDR3 Termination Regulator datasheet
PDF, 814 Кб, Версия: A, Файл опубликован: 30 сен 2013
Pin48
Package TypeZQC
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-N
Package QTY2500
МаркировкаXSL2611
Width (мм)4
Length (мм)4
Thickness (мм).74
Pitch (мм).5
Max Height (мм)1
Configuration1:1 SPST
ESD Charged Device Model0.5 kV
ESD HBM2 kV
ICC(Max)220 uA
Input/Ouput Voltage(Max)3.6 В
Количество каналов26
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L48BGA MICROSTAR JUNIOR: 16 mm2: 4 x 4(BGA MICROSTAR JUNIOR) PKG
RON Flatness(Max)0.4 Ohms
Ron Channel Match(Max)0.2 Ω
Ron(Max)4 Ohms
Ron(Typ)1.75 Ohms
Turn off Time (Disable)100 нс
Turn on Time (Enable)(Max)100 нс
VCC(Max)3.6 В
VCC(Min)3 В
VIH(Min)1.3 В
VIL(Max)0.6 В
  • Evaluation Modules & Boards: TS3DDR32611EVM
    TS3DDR32611EVM - PCDDR3 Termination Regulator Evaluation Module Board
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3DDR32611 (1)
  • TS3DDR32611ZQCR
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS3DDR32611ZQCR
