Datasheet Texas Instruments TS3DV416DGVRG4 — Даташит
СерияTS3DV416
МодельTS3DV416DGVRG4
Многоканальный дифференциальный переключатель/мультиплексор для приложений DVI/HDMI 48-TVSOP от -40 до 85
TS3DV416 datasheet
PDF, 850 Кб, Версия: C, Файл опубликован: 10 май 2006
Pin48
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаSD416
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Additional FeaturesPowered off protection
Полоса частот900 МГц
Bandwidth(Max)900 МГц
Configuration2:1 SPDT
Crosstalk-41 дБ
ESD Charged Device Model1 kV
ESD HBM(Typ)2 kV
ICC(Max)600 uA
ICC(Typ)250 uA
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)3.5 пФ
Input/Output ON-state Capacitance(Typ)10 пФ
Количество каналов8
OFF-state leakage current(Max)1 мкА
Package GroupTVSOP
Package Size: mm2:W x L48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) PKG
Время задержки распространения0.04 нс
ProtocolsHDMI,DVI,LVDS
RON Flatness(Typ)0.7 Ohms
Ron Channel Match(Max)0.2 Ω
Ron(Max)8 Ohms
Ron(Typ)4 Ohms
Turn off Time (Disable)(Max)8.5 нс
Turn on Time (Enable)(Max)11.5 нс
VCC(Max)3.6 В
VCC(Min)3 В
VIH(Min)2 В
VIL(Max)0.8 В
  • Differential Passive Signal Switch on Computing (Rev. A)
    PDF, 615 Кб, Версия: A, Файл опубликован: 28 июл 2009
    This application report describes multiplexing applications for differential bus signals and how to use Texas Instruments high-speed passive-switch products (TS3DV416, TS3DV520, TS3DV520E, TS3DV421, and others on the product roadmap such as TS3DSxxx and TS2DSxxxx) with various bandwidths and data rates. This application report describes the components that make up the system applications, includin
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3DV416 (4)
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS3DV416DGVRG4
