Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TMS320C5545AZQW06 — Даташит
СерияTMS320C5545
МодельTMS320C5545AZQW06
Процессор цифровых сигналов с фиксированной точкой 118-BGA MICROSTAR JUNIOR от -10 до 70
TMS320C5545 Fixed-Point Digital Signal Processor datasheet
PDF, 986 Кб, Версия: D, Файл опубликован: 6 окт 2016
Pin118118
Package TypeZQWZQW
Industry STD TermBGA MICROSTAR JUNIORBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY250250
CarrierJEDEC TRAY (10+1)JEDEC TRAY (10+1)
МаркировкаTMS320C5545AZQW06
Width (мм)77
Length (мм)77
Thickness (мм).74.74
Pitch (мм).5.5
Max Height (мм)11
ApplicationsVoice Triggering and Encoding,Consumer Audio,Industrial Sensor Interface,Portable Medical Equipment,Biometric Security,Home Automation,Flow Meters
DSP1 C55x
DSP MHz60,100 Max.
I2C1
Operating SystemsDSP/BIOS,VLX
Рабочий диапазон температурот -10 до 70,-40 до 85 C
Other Hardware AccelerationFFT Coprocessor
SPI1
UART1 SCI
USB1
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: BOOST5545ULP
    C5545 Booster Pack
  • Evaluation Modules & Boards: TMDX5535EZDSP
    C5535/C5545 eZdsp USB Stick Development Kit
  • Development Kits: TMDXEVM5515
    TMS320C5515 DSP Evaluation Module
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
  • Validating High Speed and Full Speed USB on the TMS320C5545 Device
    PDF, 4.5 Мб, Файл опубликован: 29 мар 2016
    This application report describes the process to validate electrical requirements of high and full speed USB operations on the TMS320C5545 device.
  • MEMS Microphone Direct PDM Input via I2S to a C5515 EVM With Software Decimation
    PDF, 686 Кб, Файл опубликован: 22 сен 2016
    This application report helps system designers demonstrate and understand the technique of directly feeding a MEMS mic output PDM stream into the Inter-IC Sound (I2S) lines of a C5515 EVM. This document is intended for audiences familiar with Digital Signal Processing, decimation and filtering techniques.
  • Usage Guidelines for C55x On-Chip Low Dropout Regulators (LDOs)
    PDF, 220 Кб, Файл опубликован: 26 июл 2016
    The C5515/C5535/C5545/C5517 devices include three low dropout regulators ANA_LDO, DSP_LDO and USB_LDO. This application report provides the guidelines for using these on-chip low dropout regulators. This document also covers the USB power-up sequence that must be followed when using the device USB.
  • Migrating From TMS320C5535 to TMS320C5545 (Rev. A)
    PDF, 321 Кб, Версия: A, Файл опубликован: 6 окт 2016
    This application report provides a summary of the similarities and differences between the TMS320C5535 and TMS320C5545 devices to minimize changes required to migrate from TMS320C5535 to TMS320CC5545.
  • Instructions to Benchmark C55 DSP Library
    PDF, 3.2 Мб, Файл опубликован: 1 апр 2016
    DSP Library (DSPLIB) is a collection of optimized C55x assembly functions that implement a wide variety of DSP functions. The TMS320C55x DSP Library Programmer’s Reference User's Guide provides cycle estimation for the execution of each function in the library. This work enables the user to measure the performances of a sub-set of the DSPLIB functions executed on real hardware, and with some addit
  • Using the TMS320C5545/35/34/33/32 Bootloader (Rev. C)
    PDF, 569 Кб, Версия: C, Файл опубликован: 6 апр 2016
  • C5000 DSP-Based Low-Power System Design
    PDF, 169 Кб, Файл опубликован: 30 ноя 2015
    Low-power consumption is one of the most important requirements for the embedded system. The C5000в„ў ultra low-power DSP family is ideal for portable devices (audio, voice and vision) and other applications that require analytics with low power.To take advantage of this feature in system design, good practices need to be carried out. This application report focuses on the Texas Instrum
  • Power Estimation and Pwr Consumption Sum for TMS320C5504/05/14/15/32/33/34/35/45 (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 апр 2016
    This application report assists in estimating the power consumption for the TMS320C5515, C5504, C5505, C5514, C5532, C5533, C5534, C5535 and C5545 devices (DSPs), using a power estimation spreadsheet.
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320C5545AZQW06
