Datasheet Texas Instruments CD74ACT273SM96 — Даташит
| Серия | CD74ACT273 |
| Модель | CD74ACT273SM96 |
Восьмеричные шлепанцы типа D со сбросом 20-SSOP от -55 до 125
Octal D Flip-Flop with Reset datasheet
PDF, 944 Кб, Версия: B, Файл опубликован: 1 июл 2002
Купить CD74ACT273SM96 на РадиоЛоцман.Цены — от 8.33 до 106 ₽36 предложений от 19 поставщиков Микросхема Бистабильный мульти, Flip Flop D-Type Bus Interface Pos-Edge 1Element 20Pin SSOP T/R | |||
| CD74ACT273SM96 Texas Instruments | от 103 ₽ | ||
| CD74ACT273SM96 Texas Instruments | от 106 ₽ | ||
| CD74ACT273SM96 Texas Instruments | по запросу | ||
| CD74ACT273SM96G4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | ACT273SM |
| Width (мм) | 5.3 |
| Length (мм) | 7.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| 3-State Output | No |
| Bits | 8 |
| F @ Nom Voltage(Max) | 90 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Drive (IOL/IOH)(Max) | 24/-24 мА |
| Package Group | SSOP |
| Package Size: mm2:W x L | 20SSOP: 56 mm2: 7.8 x 7.2(SSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | ACT |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.5 В |
| Voltage(Nom) | 5 В |
| tpd @ Nom Voltage(Max) | 12.3 нс |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD74ACT273 (13)
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
