Datasheet Texas Instruments TS3DV520ERUAR — Даташит
СерияTS3DV520E
МодельTS3DV520ERUAR
Многоканальный дифференциальный переключатель/мультиплексор для приложений DVI/HDMI 42-WQFN
TS3DV520E 5-Channel Differential 10:20 Multiplexer Switch datasheet
PDF, 827 Кб, Версия: B, Файл опубликован: 12 май 2009
АЦП азиатских производителей
Pin42
Package TypeRUA
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаSD520E
Width (мм)3.5
Length (мм)9
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
  • Differential Passive Signal Switch on Computing (Rev. A)
    PDF, 615 Кб, Версия: A, Файл опубликован: 28 июл 2009
    This application report describes multiplexing applications for differential bus signals and how to use Texas Instruments high-speed passive-switch products (TS3DV416, TS3DV520, TS3DV520E, TS3DV421, and others on the product roadmap such as TS3DSxxx and TS2DSxxxx) with various bandwidths and data rates. This application report describes the components that make up the system applications, includin
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3DV520E (1)
  • TS3DV520ERUAR
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS3DV520ERUAR
