Datasheet Texas Instruments PCA9306DCTRG4 — Даташит
СерияPCA9306
МодельPCA9306DCTRG4
2-битная двунаправленная шина I2C и преобразователь уровня напряжения SMBus 8-SM8 от -40 до 85
PCA9306 Dual Bidirectional I2C Bus and SMBus Voltage-Level Translator datasheet
PDF, 1.2 Мб, Версия: L, Файл опубликован: 22 апр 2016
Микросхема Логический контроллер, 2Bit Bidirectional I2C Bus and SMBus Voltage-Level Shifter 8-SM8 -40℃ to 85℃
PCA9306DCTRG4
11 ₽
PCA9306DCTRG4
65 ₽
МосЧип
PCA9306DCTRG4
PCA9306DCTRG4
Pin88
Package TypeDCTDCT
Industry STD TermSSOPSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка7BDY
Width (мм)2.82.8
Length (мм)2.952.95
Thickness (мм)1.291.29
Pitch (мм).65.65
Max Height (мм)1.31.3
Channel Width2
Master Side I2C Bus Capacitance Supported400 пФ
Max Frequency400 kHz
Количество выходов2
Package GroupSM8
Slave Side I2C Bus Capacitance Supported400 пФ
Special FeaturesEnable Pin,Low Voltage,Open-Drain I/O Type,5V Tolerant I/O
VCC(Max)5.5 В
VCC(Min)1.2 В
fSCLK(Max)0.4 МГц
  • Evaluation Modules & Boards: LDC2114EVM
    LDC2114 1.8V 4-Channel Inductive Touch Evaluation Module
  • Evaluation Modules & Boards: DLPLCR6500EVM
    DLPВ® LightCrafterВ™ 6500 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR9000EVM
    DLPВ® LightCrafterВ™ 9000 Evaluation Module
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
На английском языке: Datasheet Texas Instruments PCA9306DCTRG4
