Datasheet Texas Instruments CD74HC4051M96G3 — Даташит
Серия | CD74HC4051 |
Модель | CD74HC4051M96G3 |
Высокоскоростной 8-канальный аналоговый мультиплексор/демультиплексор CMOS 16-SOIC от -55 до 125
CDx4HC405x, CDx4HCT405x High-Speed CMOS Logic Analog Multiplexers and Demultiplexers datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 6 фев 2017
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | HC4051M |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Dual supply,Break-before-make |
Полоса частот | 200 МГц |
Bandwidth(Max) | 180 МГц |
Configuration | 8:1 |
ESD Charged Device Model | 0.2 kV |
ESD HBM | 0.5 kV |
Input/Ouput Voltage(Max) | 6 В |
Input/Ouput Voltage(Min) | -6 В |
Input/Output Continuous Current(Max) | 25 мА |
Input/Output OFF-state Capacitance(Typ) | 5 пФ |
Количество каналов | 1 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 1 мкА |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rating | Catalog |
Ron(Max) | 270 Ohms |
Ron(Typ) | 40 Ohms |
Supply Current(Max) | 80 uA |
Supply Current(Typ) | 8 uA |
Supply Range | 10 Max |
VIH(Min) | vcc*.7 В |
VIL(Max) | vcc*.3 В |
Vdd(Max) | 6 В |
Vdd(Min) | 2 В |
Vss(Min) | -6 В |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD74HC4051 (16)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
