Datasheet Texas Instruments TMS320P25FNL — Даташит
СерияTMS320P25
МодельTMS320P25FNL
Процессоры цифровых сигналов 68-PLCC от 0 до 70
Digital Signal Processor
PDF, 766 Кб, Файл опубликован: 1 окт 1994
15 предложений от 15 поставщиков
Цифровой сигнальный процессор DSP, DSP Fixed-Point 32Bit 40MHz 40MIPS 68Pin PLCC
TMS320P25FNL
3 113 ₽
TMS320P25FNL
8 007 ₽
Элитан
TMS320P25FNL
9 901 ₽
ТаймЧипс
TMS320P25FNL
Pin68
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Width (мм)24.23
Length (мм)24.23
Thickness (мм)4.06
Max Height (мм)4.57
RoHSНе совместим
  • Engine Knock Detection Using Spectral Analysis With TMS320C25 or TMS320C30 DSPs
    PDF, 254 Кб, Файл опубликован: 1 янв 1995
    An efficient method of detecting combustion engine knock is using spectral analysis. The detection process algorithm adapts to a no-knock reference at varying speeds and loads by using multiple frequencies. This document presents an problem overview current technology and two implementation examples are given to aid in the development of system specific hardware and software. The first system is
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Setting Up TMS320 DSP Interrupts in 'C'
    PDF, 168 Кб, Файл опубликован: 1 ноя 1994
    Four steps are required to set the TMS320 DSP interrupts: create a interrupt service routine initialize the vector table and set the memory map enable the interrupts in the CPU and enable the interrupt sources. This document shows how to set the interrupts in C C callable assembly or in-line C. Sample C code segments are provided. The appendix gives complete examples for setting interrupt vec
Серия: TMS320P25 (3)
  • Semiconductors > Processors > Other Processors
На английском языке: Datasheet Texas Instruments TMS320P25FNL
