Datasheet Texas Instruments SN74AUC2G53DCUR — Даташит
Серия | SN74AUC2G53 |
Модель | SN74AUC2G53DCUR |
Однополюсный, двухпозиционный (SPDT) аналоговый переключатель или аналоговый мультиплексор/демультиплексор 2:1 8-VSSOP от -40 до 85
SN74AUC2G53 datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 5 янв 2009
Pin | 8 | 8 |
Package Type | DCU | DCU |
Industry STD Term | VSSOP | VSSOP |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | U53R | U53Q |
Width (мм) | 2 | 2 |
Length (мм) | 2.3 | 2.3 |
Thickness (мм) | .85 | .85 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | .9 | .9 |
Полоса частот | 500 МГц |
Configuration | 2:1 SPDT |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 2.7 В |
Input/Output Continuous Current(Max) | 50 мА |
Input/Output OFF-state Capacitance(Typ) | 3 пФ |
Input/Output ON-state Capacitance(Typ) | 9 пФ |
Количество каналов | 1 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 1 мкА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG |
Rating | Catalog |
Ron(Max) | 40 Ohms |
Ron(Typ) | 6 Ohms |
Supply Current(Max) | 10 uA |
Supply Range | 2.7 Max |
VIH(Min) | vcc*.65 В |
VIL(Max) | vcc*.35 В |
Vdd(Max) | 2.7 В |
Vdd(Min) | 0.8 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC2G53 (6)
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
