Datasheet ТI OPA361AIDCKRG4 — Даташит
| Серия | OPA361 |
| Модель | OPA361AIDCKRG4 |
Видеоусилитель 3 В с внутренним усилением и фильтром 6-SC70 от -40 до 125
3V Video Amplifier with Internal Gain and Filter in SC70 datasheet
PDF, 844 Кб, Версия: A, Файл опубликован: 1 фев 2006
- OPA361 and TV DetectionPDF, 2.4 Мб, Файл опубликован: 29 июн 2008
This document describes the concept and application of a practical method to detect if a television (TV), videocassette recorder (VCR) or any other 75О© video load is connected to the output of the OPA361 video buffer, which is the video buffer for the OMAP242xв„ў series of products from Texas Instruments. In addition to TV detection, timing and layout requirements are also discussed. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA361 (4)
- OPA361AIDCKR OPA361AIDCKRG4 OPA361AIDCKT OPA361AIDCKTG4
- Semiconductors > Amplifiers > Special Function Amplifiers > Video Amplifiers
