Datasheet Texas Instruments TS5A22364QDGSRQ1 — Даташит
СерияTS5A22364-Q1
МодельTS5A22364QDGSRQ1
Automotive 0.65-О© Dual SPDT Analog Switch With Negative Signaling Capability 10-VSSOP -40 to 125
TS5A22364-Q1 0.65-Ω Dual SPDT Analog Switch with Negative Signaling Capability datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 24 июн 2016
Pin10
Package TypeDGS
Industry STD TermVSSOP
JEDEC CodeS-PDSO-G
Package QTY2500
МаркировкаSJN
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Pitch (мм).5
Max Height (мм)1.07
Additional FeaturesBreak-before-make,Supports negative voltages
Полоса частот18.3 МГц
Bandwidth(Max)18.3 МГц
Configuration2:1 SPDT
ESD Charged Device Model1.5 kV
ESD HBM2.5 kV
Input/Ouput Voltage(Max)5.5 В
Input/Ouput Voltage(Min)-3.2 В
Input/Output Continuous Current(Max)150 мА
Input/Output ON-state Capacitance(Typ)370 пФ
Количество каналов2
ON-state leakage current(Max)0.375 мкА
Package GroupVSSOP
Package Size: mm2:W x L10VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
RatingAutomotive
Ron(Max)1.3 Ohms
Ron(Typ)0.52 Ohms
Supply Current(Max)14 uA
Supply Current(Typ)6 uA
Supply Range5.5 Max
VIH(Min)1.4 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A22364-Q1 (1)
  • TS5A22364QDGSRQ1
На английском языке: Datasheet Texas Instruments TS5A22364QDGSRQ1
