Datasheet Texas Instruments SN74CB3Q3384ADBQR — Даташит
Серия | SN74CB3Q3384A |
Модель | SN74CB3Q3384ADBQR |
10-битный низковольтный переключатель шины на полевых транзисторах 2,5 В/3,3 В 24-SSOP от -40 до 85
SN74CB3Q3384A datasheet
PDF, 841 Кб, Версия: D, Файл опубликован: 20 ноя 2003
Pin | 24 |
Package Type | DBQ |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | CB3Q3384A |
Width (мм) | 3.9 |
Length (мм) | 8.65 |
Thickness (мм) | 1.5 |
Pitch (мм) | .64 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Powered off protection |
Полоса частот | 500 МГц |
Configuration | 1:1 SPST |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 64 мА |
Input/Output OFF-state Capacitance(Typ) | 3.5 пФ |
Input/Output ON-state Capacitance(Typ) | 8 пФ |
Количество каналов | 10 |
OFF-state leakage current(Max) | 1 мкА |
Package Group | SSOP |
Package Size: mm2:W x L | 24SSOP: 52 mm2: 6 x 8.65(SSOP) PKG |
Rating | Catalog |
Ron(Max) | 9 Ohms |
Ron(Typ) | 3 Ohms |
Supply Current(Max) | 2000 uA |
Supply Current(Typ) | 750 uA |
Supply Range | 3.6 Max |
VIH(Min) | 1.7 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 3.6 В |
Vdd(Min) | 2.3 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- CBT-C, CB3T, and CB3Q Signal-Switch FamiliesPDF, 584 Кб, Файл опубликован: 4 фев 2003
Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot - Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CB3Q3384A (5)
- SN74CB3Q3384ADBQR SN74CB3Q3384ADGVR SN74CB3Q3384APW SN74CB3Q3384APWG4 SN74CB3Q3384APWR
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
