Datasheet Texas Instruments SN74CBT3306CPWRE4 — Даташит
СерияSN74CBT3306C
МодельSN74CBT3306CPWRE4
Переключатель шины на двух полевых транзисторах с защитой от понижения напряжения -2 В 8-TSSOP от -40 до 85
SN74CBT3306C datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 15 окт 2003
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesLow Power
IOFF
Approx. Price (US$)0.18 | 1ku
Bandwidth(MHz)200
ConfigurationSPST
Crosstalk(dB)No
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)3
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)128
Number of Channels(#)2
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size: mm2:W x L (PKG)8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
Ron(Max)(Ohms)12
Ron(Typ)(Ohms)8
VCC(Max)(V)5.5
VCC(Min)(V)4
RoHSНе совместим
  • CBT-C, CB3T, and CB3Q Signal-Switch Families
    PDF, 584 Кб, Файл опубликован: 4 фев 2003
    Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot
На английском языке: Datasheet Texas Instruments SN74CBT3306CPWRE4
