Datasheet Texas Instruments TLE2425MJG — Даташит
СерияTLE2425
МодельTLE2425MJG
Прецизионная виртуальная земля 8-CDIP от -55 до 125
Precision Virtual Grounds datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 30 апр 2002
Package TypeJG
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)9.6
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Operating Temperature Range(C)-55 to 125
Package GroupSO
SOIC
TO-92
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
Pin/Package8SO
8SOIC
3TO-92
RatingMilitary
RoHSНе совместим
  • Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
    This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
  • Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
На английском языке: Datasheet Texas Instruments TLE2425MJG
