Datasheet Texas Instruments PCA9545AGQNR — Даташит
СерияPCA9545A
МодельPCA9545AGQNR
PCA9545A Low Voltage 4-channel IВІC and SMbus Switch datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 12 июн 2014
24 предложений от 15 поставщиков
IC INTERFACE SPECIALIZED 20BGA. Translating Switch Interface 20-BGA MICROSTAR JUNIOR (4x3). Interface - Specialized
PCA9545AGQNR
135 ₽
Эиком
PCA9545AGQNR
от 232 ₽
Hi-Tech Circuit Group
PCA9545AGQNR
PCA9545AGQNR
Pin20
Package TypeGQN
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
МаркировкаPD545A
Width (мм)3
Length (мм)4
Thickness (мм).75
Max Height (мм)1
Approx. Price (US$)0.75 | 1ku
Channel Width4
I2C Address1110 0xx
Max Frequency(kHz)400
Operating Temperature Range(C)-40 to 85
Package GroupBGA MICROSTAR JUNIOR
SOIC
TSSOP
VQFN
Package Size: mm2:W x L (PKG)20BGA MICROSTAR JUNIOR: 12 mm2: 3 x 4(BGA MICROSTAR JUNIOR)
20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
20SOIC: 132 mm2: 10.3 x 12.8(SOIC)
Simultaneously Active Channels1 to 4
Special FeaturesInterrupt Output
Reset Input
5V Tolerant I/O
VCC(Max)(V)5.5
VCC(Min)(V)2.3
fSCLK(Max)(MHz)0.4
tpd max(ns)1
RoHSНе совместим
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C Multiplexer, Switch
На английском языке: Datasheet Texas Instruments PCA9545AGQNR
