Datasheet Texas Instruments PLPV811DBVT — Даташит
СерияLPV811
МодельPLPV811DBVT
Одноканальный прецизионный наномощный операционный усилитель 450 нА 5-SOT-23 от -40 до 125
LPV811/LPV812 Precision 425 nA Nanopower Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 1 ноя 2016
Pin5
Package TypeDBV
Industry STD TermSOT
Package QTY250
CarrierSMALL T&R
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesEMI Hardened
Approx. Price (US$)0.68 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)77
CMRR(Typ)(dB)95
GBW(Typ)(MHz)0.008
Iq per channel(Max)(mA)0.00054
Iq per channel(Typ)(mA)0.00045
Number of Channels(#)1
Offset Drift(Typ)(uV/C)1
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)4.7
Package GroupSOT-23
Package Size: mm2:W x L (PKG)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)0.0017
Total Supply Voltage(Max)(+5V=5, +/-5V=10)5.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)1.6
Vn at 1kHz(Typ)(nV/rtHz)420
Vos (Offset Voltage @ 25C)(Max)(mV)0.37
RoHSTBD
  • Comparing EMI Performance of LPV802 with Other Devices in a Gas Sensor App
    PDF, 4.0 Мб, Файл опубликован: 18 окт 2016
    Passing the IEC61000-4-3 Radiated EMI test is a requirement for preparing a product for many industrial,medical and consumer markets. This application note presents the results of a simple comparison of theLPV802 nanopower operational amplifier and two other competing devices in a Carbon Monoxide gassensor circuit while subjected to IEC61000-4-3 EMC test conditions.
  • Precision Voltage Offset: When Does it Matter? (Rev. A)
    PDF, 271 Кб, Версия: A, Файл опубликован: 2 ноя 2016
Серия: LPV811 (3)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=250uA)
На английском языке: Datasheet Texas Instruments PLPV811DBVT
