Datasheet Texas Instruments SN74CBT3861DWRE4 — Даташит
| Серия | SN74CBT3861 |
| Модель | SN74CBT3861DWRE4 |
10-битный переключатель шины FET 24-SOIC от -40 до 85
10-Bit FET Bus Switch--SN74CBT3861 datasheet
PDF, 807 Кб, Версия: D, Файл опубликован: 20 окт 2000
Купить SN74CBT3861DWRE4 на РадиоЛоцман.Цены — от 23 до 80 ₽11 предложений от 11 поставщиков IC SWITCH BUS FET 10BIT 24-SOIC. Bus Switch 10 x 1:1 24-SOIC. Logic - Signal Switches, Multiplexers, Decoders | |||
| SN74CBT3861DWRE4 Texas Instruments | 31 ₽ | ||
| SN74CBT3861DWRE4 Texas Instruments | 80 ₽ | ||
| SN74CBT3861DWRE4 Texas Instruments | по запросу | ||
| Pin | 24 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | CBT3861 |
| Width (мм) | 7.5 |
| Length (мм) | 15.4 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Полоса частот | 200 МГц |
| Configuration | 1:1 SPST |
| Input/Ouput Voltage(Max) | 5.5 В |
| Input/Output Continuous Current(Max) | 128 мА |
| Input/Output OFF-state Capacitance(Typ) | 5 пФ |
| Количество каналов | 10 |
| OFF-state leakage current(Max) | 1 мкА |
| ON-state leakage current(Max) | 1 мкА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG |
| Rating | Catalog |
| Ron(Max) | 15 Ohms |
| Ron(Typ) | 5 Ohms |
| Supply Current(Max) | 50 uA |
| Supply Range | 5.5 Max |
| VIH(Min) | 2 В |
| VIL(Max) | 0.8 В |
| Vdd(Max) | 5.5 В |
| Vdd(Min) | 4 В |
| Vss(Max) | N/A В |
| Vss(Min) | N/A В |
- Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBT3861 (7)
- SN74CBT3861DBQR SN74CBT3861DBQRG4 SN74CBT3861DW SN74CBT3861DWE4 SN74CBT3861DWR SN74CBT3861DWRE4 SN74CBT3861PWR
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
