Клеммники KEEN SIDE
Datasheet Texas Instruments TS2A116ERUTR — Даташит
СерияTS2A116E
МодельTS2A116ERUTR
Микросхема аутентификации и связи аудиогарнитуры 12-UQFN от -40 до 85
TS2A116E AUDIO ACCESSORY COMMUNICATOR AND AUTHENTICATION IC datasheet
PDF, 129 Кб, Файл опубликован: 23 апр 2014
Pin12
Package TypeRUT
Industry STD TermUQFN
JEDEC CodeR-PQFP-N
Package QTY3000
Width (мм)1.7
Length (мм)2
Thickness (мм).5
Pitch (мм).4
Max Height (мм).55
ICC(Max)90 uA
Package GroupUQFN
Package Size: mm2:W x L12UQFN: 3 mm2: 1.7 x 2(UQFN) PKG
VCC(Max)3.6 В
VCC(Min)1.7 В
RoHSSee ti.com
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS2A116E (1)
  • TS2A116ERUTR
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS2A116ERUTR
