Datasheet Texas Instruments SN74LVC1G32DBVT — Даташит
СерияSN74LVC1G32
МодельSN74LVC1G32DBVT
Одиночный вентиль положительного ИЛИ с 2 входами 5-SOT-23 от -40 до 125
SN74LVC1G32 Single 2-Input Positive-OR Gate datasheet
PDF, 1.6 Мб, Версия: V, Файл опубликован: 22 мар 2016
Pin5555555
Package TypeDBVDBVDBVDBVDBVDBVDBV
Industry STD TermSOT-23SOT-23SOT-23SOT-23SOT-23SOT-23SOT-23
JEDEC CodeR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-GR-PDSO-G
Package QTY250250250250250250250
CarrierSMALL T&RSMALL T&RSMALL T&RSMALL T&RSMALL T&RSMALL T&RSMALL T&R
МаркировкаC32FC32KC32RC32PC32SC32HC325
Width (мм)1.61.61.61.61.61.61.6
Length (мм)2.92.92.92.92.92.92.9
Thickness (мм)1.21.21.21.21.21.21.2
Pitch (мм).95.95.95.95.95.95.95
Max Height (мм)1.451.451.451.451.451.451.45
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачатьСкачатьСкачать
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyOR Gate
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)7.2,4.4,3.6,3.4 нс
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Designing and Manufacturing with TI's X2SON Packages
    PDF, 134 Кб, Файл опубликован: 23 авг 2017
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G32DBVT
