Datasheet Texas Instruments SN74CBT3245ADBLE — Даташит
СерияSN74CBT3245A
МодельSN74CBT3245ADBLE
Восьмеричный переключатель шины на полевых транзисторах 20-SSOP от -40 до 85
SN74CBT3245A datasheet
PDF, 1.4 Мб, Версия: Q, Файл опубликован: 8 дек 2004
Pin20
Package TypeDB
Industry STD TermSSOP
Width (мм)5.3
Length (мм)7.2
Thickness (мм)1.95
Max Height (мм)2
Approx. Price (US$)0.29 | 1ku
Bandwidth(MHz)200
ConfigurationSPST
ICC(Max)(uA)50
Input/Ouput Voltage(Max)(V)5.5
Input/Output Continuous Current(Max)(mA)128
Number of Channels(#)8
Operating Temperature Range(C)-40 to 85
Package GroupSSOP
Package Size: mm2:W x L (PKG)20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP)
Ron(Max)(Ohms)12
Ron(Typ)(Ohms)8
VCC(Max)(V)5.5
VCC(Min)(V)4
RoHSНе совместим
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
  • Semiconductors > Switches and Multiplexers > Signal Switches > Digital Switch
На английском языке: Datasheet Texas Instruments SN74CBT3245ADBLE
