Datasheet Texas Instruments 5962-9555601Q2A — Даташит
| Серия | TLE2425 |
| Модель | 5962-9555601Q2A |
Precision Virtual Ground 20-LCCC от -55 до 125
Precision Virtual Grounds datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 30 апр 2002
| 5962-9555601Q2A Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 20 |
| Package Type | FK |
| Industry STD Term | LCCC |
| JEDEC Code | S-CQCC-N |
| Width (мм) | 8.89 |
| Length (мм) | 8.89 |
| Thickness (мм) | 1.83 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Operating Temperature Range(C) | -55 to 125 |
| Package Group | SO SOIC TO-92 |
| Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
| Pin/Package | 8SO 8SOIC 3TO-92 |
| Rating | Military |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Choosing an ADC and Op Amp for Minimum OffsetPDF, 72 Кб, Файл опубликован: 28 окт 1999
Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi - Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
Серия: TLE2425 (24)
- Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
59629555601Q2A, 5962 9555601Q2A
