Datasheet Texas Instruments 5962-89611012A — Даташит
СерияUC1706
Модель5962-89611012A
Высокоскоростные драйверы MOSFET с ограничением тока 20-LCCC от -55 до 125
Dual Output Driver datasheet
PDF, 750 Кб, Версия: A, Файл опубликован: 2 май 2001
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Package QTY1
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Fall Time40 нс
Основные особенностиAnalog Shutdown with Latch,Inhibit Circuit,Thermal Shutdown
Input ThresholdTTL
Input VCC(Max)40 В
Input VCC(Min)5 В
Количество каналов2
Package GroupLCCC
Peak Output Current1.5 A
Power SwitchMOSFET
Prop Delay100 нс
RatingMilitary
Rise Time40 нс
RoHSSee ti.com
  • U-118 New Driver ICs Optimize High-Speed Power MOSFET Switching Characteristics
    PDF, 573 Кб, Файл опубликован: 5 сен 1999
    The UC3705 family of power drivers is made with a high speed Schottky process to interface between low-level control functions and high-power switching devices particularly power MOSFETs. These devices are also an optimum choice for capacitive line drivers where up to 1.5 amps may be switched in either direction. With both inverting and non-inverting inputs available logic signals of either pola
  • U-137 Practical Considerations in High Performance MOSFET IGBT and MCT Gate
    PDF, 244 Кб, Файл опубликован: 5 сен 1999
    The switch-mode power supply industry's trend towards higher conversion frequencies is justified by the dramatic improvement in obtaining higher power densities. And as these frequencies are pushed towards and beyond one MHz the MOSFET transition periods can become a significant portion of the total switching period. Losses associated with the overlap of switch voltage and current not only degrad
Серия: UC1706 (5)
  • Semiconductors > Space & High Reliability > Power Management Products > MOSFET and IGBT Gate Driver
596289611012A, 5962 89611012A
На английском языке: Datasheet Texas Instruments 5962-89611012A
