Datasheet Texas Instruments TLE2425ILPE3 — Даташит
СерияTLE2425
МодельTLE2425ILPE3
Прецизионная виртуальная площадка 3-TO-92
Precision Virtual Grounds datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 30 апр 2002
Pin3
Package TypeLP
Industry STD TermTO-92
JEDEC CodeO-PBCY-W
Package QTY1000
CarrierBULK
Маркировка2425I
Width (мм)4.3
Length (мм)4.3
Thickness (мм)3.6
Max Height (мм)5.34
Initial Accuracy(Max)N/A %
Iout/Iz(Max)55 мА
Iq(Max)N/A uA
Iq(Typ)N/A uA
LFN 0.1-10Hz(Typ)N/A ОјVpp
Package GroupTO-92
Package Size: mm2:W x L3TO-92: 18 mm2: 4.3 x 4.3(TO-92) PKG
Pin/Package3TO-92, 8SO, 8SOIC
Special FeaturesN/A
Temp Coeff(Typ)20 ppm/ degree C
VON/A В
Vin(Max)40 В
Vin(Min)4 В
WBN 10-10 kHz(Typ)100 uVrms
  • Using References to Generate Offsets for the TLC55xx Family Data Converters (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 29 июл 2002
    This application report describes the process for using references to generate offsets for Texas Instrument?s TLC55XX family data converters.
  • Choosing an ADC and Op Amp for Minimum Offset
    PDF, 72 Кб, Файл опубликован: 28 окт 1999
    Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
  • Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
На английском языке: Datasheet Texas Instruments TLE2425ILPE3
