Datasheet Texas Instruments TS3USB3000RLSR — Даташит
СерияTS3USB3000
МодельTS3USB3000RLSR
DPDT USB 2.0 Высокоскоростной мобильный канал высокой четкости (MHL) (6,1 ГГц) Переключатель 10-UQFN от -40 до 85
TS3USB3000 DPDT USB 2.0 High-Speed and Mobile High-Definition Link (MHL) 6.1-GHz Switch datasheet
PDF, 2.0 Мб, Версия: C, Файл опубликован: 10 янв 2017
Pin10
Package TypeRLS
Package QTY3000
Width (мм)2
Length (мм)1.5
Thickness (мм).5
Additional FeaturesUSB 2.0
Over-Voltage Tolerance (OVT)
Current Leakage Protection
Logic Controlled (Output Enabled)
Approx. Price (US$)0.35 | 1ku
Bandwidth(MHz)6100
Configuration1:2 SPDT
Crosstalk(Typ)(dB)-37
ESD Charged Device Model(Typ)(kV)1
ESD HBM(Typ)(kV)3.5
ICC(Max)(uA)50
ICC(Typ)(uA)30
Input/Ouput Voltage(Max)(V)3.6
Input/Output OFF-state Capacitance(Typ)(pF)1.6
Input/Output ON-state Capacitance(Typ)(pF)1.4
Number of Channels(#)2
OFF-state leakage current(Max)(ВµA)2
ON-state resistance flatness(Typ)(Ω)1
Off Isolation(Typ)(dB)-34
Operating Temperature Range(C)-40 to 85
Package GroupUQFN
Package Size: mm2:W x L (PKG)10UQFN: 3 mm2: 2 x 1.5(UQFN)
Powered-off leakage current(Max)(ВµA)10
Powered-on leakage current(Max)(ВµA)2
Propagation Delay(Typ)(ns)0.1
Ron Channel Match(Typ)(Ω)0.1
Ron(Max)(Ohms)7.5
Ron(Typ)(Ohms)4.6
Turn off Time (Disable)(Max)(ns)400
Turn on Time (Enable)(Max)(ns)400
VCC(Max)(V)4.3
VCC(Min)(V)2.7
RoHSTBD
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: TS3USB3000 (3)
  • Semiconductors > Interface > USB > USB/MHL Switch
На английском языке: Datasheet Texas Instruments TS3USB3000RLSR
