Datasheet Texas Instruments OPA452FA — Даташит
СерияOPA452
МодельOPA452FA
Операционные усилители 80 В, 50 мА 7-DDPAK/TO-263
OPA452, 453: 80V, 50mA Operational Amplifiers datasheet
PDF, 917 Кб, Версия: C, Файл опубликован: 10 ноя 2003
41 предложений от 21 поставщиков
OPA452FA/500
от 91 ₽
Зенер
Россия и страны ТС
OPA452FA/500
от 360 ₽
Эиком
OPA452FA/500
от 839 ₽
ТаймЧипс
OPA452FA/500
Pin7
Package TypeKTW
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Width (мм)8.89
Length (мм)10.1
Thickness (мм)4.44
Max Height (мм)4.65
Рекомендуемая замена
ReplacementOPA452FAKTWT
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)2.90 | 1ku
АрхитектураFET
CMRR(Min)(dB)86
CMRR(Typ)(dB)94
GBW(Typ)(MHz)1.8
Input Bias Current(Max)(pA)100
Iq per channel(Max)(mA)6.5
Iq per channel(Typ)(mA)5.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)5
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)50
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Rail-to-RailNo
Slew Rate(Typ)(V/us)7.2
Total Supply Voltage(Max)(+5V=5, +/-5V=10)80
Total Supply Voltage(Min)(+5V=5, +/-5V=10)20
Vos (Offset Voltage @ 25C)(Max)(mV)3
RoHSНе совместим
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA452FA
