Datasheet Texas Instruments LP5907SNX-1.9 — Даташит
СерияLP5907
МодельLP5907SNX-1.9
250 мА Сверхмалошумящий LDO с низким IQ 4-X2SON от -40 до 125
LP5907 250-mA Ultra-Low-Noise, Low-IQ LDO datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 6 сен 2016
Pin4
Package TypeDQN
Industry STD TermX2SON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка3Z
Width (мм)1
Length (мм)1
Thickness (мм).37
Max Height (мм).4
Точность2 %
Fixed Output Options1.2,1.5,1.8,1.9,2.2,2.5,2.7,2.75,2.8,2.85,2.9,3,3.1,3.2,3.3,3.7,4,4.5 В
Iout(Max)0.25 A
Iq(Typ)0.012 мА
Noise6.5 uVrms
Output Capacitor TypeCeramic
Output OptionsFixed Output
PSRR @ 100KHz60 дБ
Package GroupX2SON
Package Size: mm2:W x L4X2SON: 1 mm2: 1 x 1(X2SON) PKG
Regulated Outputs1
Special FeaturesEnable,Output Discharge
Thermal Resistance ОёJA193 В°C/W
Vdo(Typ)50 мВ
Vin(Max)5.5 В
Vin(Min)2.2 В
Vout(Max)4.5 В
Vout(Min)1.2 В
  • Evaluation Modules & Boards: DAC38RF82EVM
    DAC38RF82 Dual-Channel, 14-Bit, 9-GSPS, 1x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: DAC38RF86EVM
    DAC38RF86 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 9 GHz GSM PLL DAC Evaluation Module
  • Evaluation Modules & Boards: TSW40RF80EVM
    2T2R RF-Sampling Transceiver With Dual 14-Bit 3GSPS ADC, Dual 14-Bit 9GSPS DAC and Clocking Solution
  • Evaluation Modules & Boards: LMK61A2-100M00EVM
    LMK61A2-100M00 Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: LMK04616EVM
    LMK04616 Evaluation Module
  • Evaluation Modules & Boards: LMK61E2-100M00EVM
    LMK61E2-100M00EVM Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: LMK61E2-312M50EVM
    LMK61E2-312M50EVM Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: DAC38RF89EVM
    DAC38RF89 Dual-Channel, 14-Bit, 8.4GSPS, 1x-24x Interpolating, 5 & 7.5 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: TUSB211PICO-EVM
    TUSB211 PICO High-Speed Signal Conditioner Compensating for Transmission Channel ISI Signal EVM
  • Evaluation Modules & Boards: DAC38RF87EVM
    DAC38RF87 Dual-Channel, 14-Bit, 6.2-GSPS, 6x-24x Interpolating, 6-GHz GSM PLL DAC Evaluation Module
  • Evaluation Modules & Boards: LMK61PDEVM
    LMK61PDEVM Ultra-Low-Jitter Pin Selectable Oscillator EVM
  • Evaluation Modules & Boards: TUSB542EVM
    TUSB542 USB Type-C 5Gbps Redriver 2:1 MUX Evaluation Module
  • Evaluation Modules & Boards: LMK61E0MEVM
    LMK61E0M Ultra-Low-Jitter Programmabler Oscillator Evaluation Module
  • Evaluation Modules & Boards: LMK61E2EVM
    LMK61E2EVM Ultra-Low-Jitter Programmable Oscillator Evaluation Module
  • Evaluation Modules & Boards: LMK61A2-312M50EVM
    LMK61A2-312M50 Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: TUSB1002EVM
    TUSB1002 USB3.1 10Gbps Dual-Channel Linear Redriver Evaluation Module
  • Evaluation Modules & Boards: LMK61E2-156M25EVM
    LMK61E2-156M25EVM Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: LP5907UV-3.0EVM
    Evaluation Board for the LP5907UV-3.0
  • Evaluation Modules & Boards: LP5907UV-3.3EVM
    Evaluation Board for the LP5907UV-3.3
  • Evaluation Modules & Boards: DAC38RF80EVM
    DAC38RF80 Dual-Channel, 14-Bit, 9-GSPS, 6x-24x Interpolating, 6 & 9 GHz PLL DAC Evaluation Module
  • Evaluation Modules & Boards: USB-REDRIVER-EVM
    USB 2.0 and USB 3.0 Redriver Evaluation Module
  • Evaluation Modules & Boards: TUSB522PEVM
    TUSB522P Evaluation Module USB3.1 5Gbps Dual Channel Redriver
  • Evaluation Modules & Boards: TUSB211RPTREVM
    TUSB211RPTREVM Evaluation Module
  • Evaluation Modules & Boards: LMK04610EVM
    LMK04610 Ultra Low-Noise and Low Power JESD204B Compliant Clock Jitter Cleaner With Dual PLLs EVM
  • Evaluation Modules & Boards: LP5907UV-1.8EVM
    Evaluation Board for the LP5907UV-1.8
  • Evaluation Modules & Boards: LP5907UV-2.8EVM
    Evaluation Board for the LP5907UV-2.8
  • Evaluation Modules & Boards: LP5907UV-1.2EVM
    Evaluation Board for the LP5907UV-1.2
  • Evaluation Modules & Boards: LMK62E2-156M25EVM
    LMK62E2-156M Low-Jitter Single-Output Fixed Frequency Oscillator Evaluation Module
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • Evaluation Modules & Boards: LMK61A2-125M00EVM
    LMK61A2-125M00 Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: TUSB212EVM
    USB 2.0 High Speed Signal Conditioner Evaluation Module
  • Evaluation Modules & Boards: LMK61A2-156M25EVM
    LMK61A2-156M25 Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: LMK61E2-125M00EVM
    LMK61E2-125M00EVM Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Evaluation Modules & Boards: CDCI6214EVM
    CDCI6214 Ultra-Low Power Clock Generator Evaluation Module
  • Evaluation Modules & Boards: LMK61I2-100M00EVM
    LMK61I2-100M00 Ultra-Low-Jitter Fixed Frequency Oscillator EVM
  • Analog Applications Journal 3Q 2015
    PDF, 7.1 Мб, Файл опубликован: 24 июл 2015
  • LDOs Thermal Performance in Small SMD Packages
    PDF, 1.3 Мб, Файл опубликован: 22 апр 2016
    The application report LDOs Thermal Performance in Small SMD Packages covers common questions regarding linear regulators and thermal metrics. Thisdocument also provides low dropout linear regulators (LDO) thermal performance comparison betweencontinuous load conditions and pulsed load conditions.
  • Transient-testing platforms and automation techniques for LDOs and buck regulato
    PDF, 4.4 Мб, Файл опубликован: 24 июл 2015
LP5907SNX1.9, LP5907SNX 1.9
На английском языке: Datasheet Texas Instruments LP5907SNX-1.9
