Datasheet Texas Instruments LM3528TME/NOPB — Даташит
| Серия | LM3528 |
| Модель | LM3528TME/NOPB |
Высокоэффективный многоэкранный светодиодный драйвер с экспоненциальным регулированием яркости 128, шагом 12-DSBGA от -40 до 85
LM3528 HE, Multi-dsplay LED Drvr w/128 Exp Dim Steps & OLED PS datasheet
PDF, 1.8 Мб, Версия: B, Файл опубликован: 3 май 2013
Купить LM3528TME/NOPB на РадиоЛоцман.Цены — от 56 до 371 ₽22 предложений от 14 поставщиков Драйвер LED , TEXAS INSTRUMENTS LM3528TME/NOPB Led Driver, 2Outputs, Boost (Step Up), 2.5V-5.5V in, 1.27MHz switch, 20.6V/30mA out, SMD-12 | |||
| LM3528TME/NOPB Texas Instruments | 84 ₽ | ||
| LM3528TME/NOPB Rochester Electronics | 122 ₽ | ||
| LM3528TME/NOPB Texas Instruments | 146 ₽ | ||
| LM3528TME/NOPB Texas Instruments | от 371 ₽ | ||
| Pin | 12 |
| Package Type | YFQ |
| Industry STD Term | DSBGA |
| JEDEC Code | R-XBGA-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Маркировка | SE |
| Thickness (мм) | .42 |
| Pitch (мм) | .4 |
| Max Height (мм) | .675 |
| Mechanical Data | Скачать |
| Количество каналов | 2 |
| Duty Cycle(Max) | 90 % |
| LED | 12 |
| LED Current Per Channel | 20 мА |
| Package Group | DSBGA |
| Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
| Peak Efficiency | 88 % |
| Rating | Catalog |
| Shutdown Current(Typ) | 1.8 uA |
| Special Features | OVP |
| Switching Frequency(Max) | 1250 kHz |
| Topology | Boost |
| Тип | Inductive |
| Vin(Max) | 5.5 В |
| Vin(Min) | 2.7 В |
| Vout(Max) | 22 В |
- Evaluation Modules & Boards: LM3528TMEV
LM3528TM Evaluation Board
- Analog PWM Dimming in White-LED DriversPDF, 539 Кб, Файл опубликован: 21 дек 2016
Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
Серия: LM3528 (2)
- LM3528TME/NOPB LM3528TMX/NOPB
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
