Datasheet Texas Instruments ADS1208IPWG4 — Даташит
СерияADS1208
МодельADS1208IPWG4
Модулятор 10 МГц со встроенным токовым возбуждением для датчиков Холла 16-TSSOP от -40 до 85
2nd-Order Delta-Sigma Modulator with Excitation for Hall Elements datasheet
PDF, 420 Кб, Версия: A, Файл опубликован: 30 мар 2005
Микросхема Преобразователь AD, 10MHz Modulator with built in current excitation for Hall sensors 16-TSSOP -40℃ to 85℃
ADS1208IPWG4
371 ₽
ADS1208IPWG4
578 ₽
МосЧип
ADS1208IPWG4
ADS1208IPWG4
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаAZ1208I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)8 +/-LSB
Input Range(Max)5 В
Тип входаDifferential
Integrated FeaturesExcitation Current Sources (iDACs),Oscillator
InterfaceSerial
Multi-Channel ConfigurationN/A
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Power Consumption(Typ)64 mW
Reference ModeExt,Int
Разрешение16 Bits
SINAD81.5 дБ
SNR82 дБ
Sample Rate (max)40kSPS SPS
Sample Rate(Max)0.04 MSPS
THD(Typ)-91 дБ
  • Evaluation Modules & Boards: AMC1210MB-EVM
    AMC1210 Mother Board
  • Clock Divider Circuit for the ADS1202 in Mode 3 Operation
    PDF, 151 Кб, Файл опубликован: 15 сен 2003
    The ADS1202 is a precision, 80dB dynamic range, delta-sigma (О”ОЈ) modulator operating from a single +5V supply. The differential inputs are ideal for direct connections to transducers or low-level signals. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital conversion with no missing codes. This application note describes ho
  • Using the ADS1202 Reference Design
    PDF, 448 Кб, Файл опубликован: 19 ноя 2003
    This application report describes the characteristics, operation, and use of the ADS1202 reference design. It includes two isolated ADS1202 circuits for a variety of applications and a SincВі filter implemented in a XilinxВ® XC2S150 field-programmable gate array. Optional optocouplers provide addtional isolation. A complete circuit description and schematic diagram are included.
  • Combining ADS1202 with FPGA Digital Filter for Current Msrmnt in Motor Cntrl App
    PDF, 375 Кб, Файл опубликован: 28 апр 2003
    The ADS1202 is a precision, 80dB dynamic range, delta-sigma(О”ОЈ) modulator operating from a single +5V supply. The differential inputs are ideal for direct connections to transducers or low-level signals, such as shunt resistors. With the appropriate digital filter and modulator rate, the device can be used to achieve 15-bit analog-to-digital (A/D) conversion with no missing codes. This
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1208 (2)
На английском языке: Datasheet Texas Instruments ADS1208IPWG4
