Datasheet ТI LM2931AZ-5.0/LFT3 — Даташит
| Серия | LM2931-N |
| Модель | LM2931AZ-5.0/LFT3 |
Регуляторы серии с низким падением напряжения 3-TO-92 от -40 до 85
LM2931 Series Low Dropout Regulators datasheet
PDF, 3.4 Мб, Версия: G, Файл опубликован: 3 апр 2013
- AB-12 Wide Adjustable Range PNP Voltage Regulator (Rev. B)PDF, 47 Кб, Версия: B, Файл опубликован: 6 май 2013
This application note discusses the PNP voltage regulator. - High-Efficiency Reg has Low Drop-Out Voltage (Rev. B)PDF, 60 Кб, Версия: B, Файл опубликован: 23 апр 2013
Conventional regulators have a high drop-out voltage that is a function of the total output current.However with just a regulator chip an external transistor and a few passive components this designforms a high output current regulator with a limited input voltage and high efficiency. The circuit presentedhas a drop-out of 0.7V at 5A load current and 1.3V at a current level of as high as - TO-92 Packing Options / Ordering Instructions (Rev. A)PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
Серия: LM2931-N (31)
- LM2931AM-5.0 LM2931AM-5.0/NOPB LM2931AMX-5.0 LM2931AMX-5.0/NOPB LM2931AS-5.0 LM2931AS-5.0/NOPB LM2931ASX-5.0 LM2931ASX-5.0/NOPB LM2931AT-5.0 LM2931AT-5.0/NOPB LM2931AZ-5.0/LFT1 LM2931AZ-5.0/LFT3 LM2931AZ-5.0/LFT4 LM2931AZ-5.0/NOPB LM2931CM LM2931CM/NOPB LM2931CMX LM2931CMX/NOPB LM2931CS LM2931CS/NOPB LM2931CT/NOPB LM2931M-5.0 LM2931M-5.0/NOPB LM2931MX-5.0 LM2931MX-5.0/NOPB LM2931S-5.0/NOPB LM2931T-5.0 LM2931T-5.0/NOPB LM2931Z-5.0/LFT1 LM2931Z-5.0/LFT2 LM2931Z-5.0/NOPB
LM2931AZ5.0/LFT3, LM2931AZ 5.0/LFT3
