Datasheet Texas Instruments TPS65135RTER — Даташит
СерияTPS65135
МодельTPS65135RTER
Преобразователь с разделенной шиной, одноиндукторный стабилизатор с несколькими выходами (SIMO) 16-WQFN от -40 до 85
TPS65135 Single-Inductor, Multiple-Output Regulator datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 30 янв 2017
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаCCR
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Iout(Max)0.08 A
Iq(Typ)7 мА
Package GroupWQFN
TopologySplit-Rail
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.5 В
Vout(Max)6 В
Vout(Min)3 В
Vout2(Max)-2.5 В
Vout2(Min)-7 В
  • Evaluation Modules & Boards: TPS65135EVM-265
    TPS65135 SIMO Converter Evaluation Module
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65135 (1)
  • TPS65135RTER
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65135RTER
