Datasheet Texas Instruments SN74LVCH162244ADGVR — Даташит
| Серия | SN74LVCH162244A |
| Модель | SN74LVCH162244ADGVR |
16-битный буфер/драйвер с выходами с 3 состояниями 48-TVSOP от -40 до 85
SN74LVCH162244A 16-Bit Buffer/Driver with 3-State Outputs datasheet
PDF, 784 Кб, Версия: L, Файл опубликован: 2 май 2014
16-BIT BUFFER/DRIVER WITH 3-STATE OUTPUTS | |||
| SN74LVCH162244ADGVR Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 48 |
| Package Type | DGV |
| Industry STD Term | TVSOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 4.4 |
| Length (мм) | 9.7 |
| Thickness (мм) | 1.05 |
| Pitch (мм) | .4 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
Рекомендуемая замена
| Replacement | SN74LVCH162244AVR |
| Replacement Code | S |
| Approx. Price (US$) | 0.49 | 1ku |
| Bits(#) | 16 |
| F @ Nom Voltage(Max)(Mhz) | 100 |
| ICC @ Nom Voltage(Max)(mA) | 0.02 |
| Тип входа | TTL/CMOS |
| Operating Temperature Range(C) | -40 to 125 |
| Output Drive (IOL/IOH)(Max)(mA) | -12/12 |
| Тип выхода | LVTTL |
| Package Group | TVSOP |
| Package Size: mm2:W x L (PKG) | 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max)(V) | 3.6 |
| VCC(Min)(V) | 1.65 |
| Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
| tpd @ Nom Voltage(Max)(ns) | 10.2 6.4 5.6 4.4 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Simultaneous-Switching Performance of TI Logic Devices (Rev. B)PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
Серия: SN74LVCH162244A (8)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
