Datasheet Texas Instruments TS5A23157RSERG4 — Даташит
Серия | TS5A23157 |
Модель | TS5A23157RSERG4 |
Двойной аналоговый переключатель SPDT 10 Ом 10-UQFN от -40 до 85
TS5A23157 Dual 10-Ω SPDT Analog Switch datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 30 июн 2015
![]() 10 предложений от 10 поставщиков Чип интерфейса, Dual 10Ω SPDT Analog Switch 10-UQFN -40℃ to 85℃ | |||
TS5A23157RSERG4 Texas Instruments | 29 ₽ | ||
TS5A23157RSERG4 | по запросу | ||
TS5A23157RSERG4 Texas Instruments | по запросу |
Pin | 10 |
Package Type | RSE |
Industry STD Term | UQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | JBO |
Width (мм) | 2 |
Length (мм) | 1.5 |
Thickness (мм) | .55 |
Pitch (мм) | .5 |
Max Height (мм) | .6 |
Mechanical Data | Скачать |
Additional Features | Break-before-make |
Полоса частот | 220 МГц |
Bandwidth(Max) | 220 МГц |
Configuration | 2:1 SPDT |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 50 мА |
Input/Output OFF-state Capacitance(Typ) | 5.5 пФ |
Input/Output ON-state Capacitance(Typ) | 17.5 пФ |
Количество каналов | 2 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 1 мкА |
Package Group | UQFN |
Package Size: mm2:W x L | 10UQFN: 3 mm2: 2 x 1.5(UQFN) PKG |
Rating | Catalog |
Ron(Max) | 140 Ohms |
Ron(Typ) | 10 Ohms |
Supply Current(Max) | 10 uA |
Supply Range | 5.5 Max |
VIH(Min) | vcc*.7 В |
VIL(Max) | vcc*.3 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 1.65 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A23157 (7)
- TS5A23157DGSR TS5A23157DGSRE4 TS5A23157DGSRG4 TS5A23157DGST TS5A23157DGSTG4 TS5A23157RSER TS5A23157RSERG4
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
