Datasheet Texas Instruments 74AC16823DLR — Даташит
Серия74AC16823
Модель74AC16823DLR
18-битные триггеры с интерфейсом шины и выходами с 3 состояниями 56-SSOP от -40 до 85
Микросхема Логический чип, 18Bit Bus Interface Flip-Flops with 3-State Outputs 56-SSOP -40℃ to 85℃
74AC16823DLR
121 ₽
74AC16823DLR
244 ₽
74AC16823DLR
304 ₽
Зенер
Россия и страны ТС
74AC16823DLR
678 ₽
Pin56
Package TypeDL
Industry STD TermSSOP
Width (мм)7.49
Length (мм)18.41
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: 74AC16823 (2)
  • Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Flip-Flop
На английском языке: Datasheet Texas Instruments 74AC16823DLR
