Datasheet ТI SN74LVC07AQPWRG4Q1 — Даташит
СерияSN74LVC07A-Q1
МодельSN74LVC07AQPWRG4Q1
Datasheet Texas Instruments SN74LVC07AQPWRG4Q1
Автомобильный каталог Шестигранный буфер/драйвер с выходами с открытым стоком 14-TSSOP от -40 до 125
Hex Buffer and Driver With Open-Drain Outputs datasheet
PDF, 739 Кб, Версия: D, Файл опубликован: 17 июл 2012
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC07A-Q1 (2)
На английском языке: Datasheet Texas Instruments SN74LVC07AQPWRG4Q1
Публикации по теме
Политика конфиденциальности
