Datasheet Texas Instruments SN74AUC2G07DCKRG4 — Даташит
СерияSN74AUC2G07
МодельSN74AUC2G07DCKRG4
Двойной буфер/драйвер с выходами с открытым стоком 6-SC70 от -40 до 85
Dual Buffer/Driver With Open-Drain Outputs datasheet
PDF, 967 Кб, Версия: D, Файл опубликован: 17 июн 2008
Pin666
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаUVRUVFUV5
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
3-State OutputNo
Bits2
F @ Nom Voltage(Max)250 Mhz
Gate TypeOPEN DRAIN BUFFER
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd,open drain
Sub-FamilyNon-Inverting Buffer/Driver
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)1.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)4.3,3,2.2,2.5,1.6 нс
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC2G07DCKRG4
