Оптопары и оптореле Megawin
Datasheet Texas Instruments OPA547TG3 — Даташит
СерияOPA547
МодельOPA547TG3
Высоковольтный сильноточный операционный усилитель с возможностью отключения 7-TO-220 от -40 до 85
High-Voltage, High-Current Operational Amplifier datasheet
PDF, 925 Кб, Версия: F, Файл опубликован: 21 июл 2005
Pin7
Package TypeKVT
Industry STD TermTO-220
JEDEC CodeR-PZFM-T
Package QTY50
МаркировкаOPA547T
Width (мм)8.34
Length (мм)10.16
Thickness (мм)4.6
Max Height (мм)4.7
Additional FeaturesAdj Current Limit,Shutdown
АрхитектураBipolar
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)500000 pA
Iq per channel(Max)15 мА
Iq per channel(Typ)10 мА
Количество каналов1
Offset Drift(Typ)25 uV/C
Output Current(Typ)500 мА
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Rail-to-RailIn to V-
Slew Rate(Typ)6 V/us
Total Supply Voltage(Max)60 +5V=5, +/-5V=10
Total Supply Voltage(Min)8 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: OPA547EVM
    OPA547 Evaluation Module
  • Evaluation Modules & Boards: OPAMPEVM
    Universal Operational Amplifier Evaluation Module
  • DC MOTOR SPEED CONTROLLER: Control a DC Motor without Tachometer Feedback
    PDF, 50 Кб, Файл опубликован: 27 сен 2000
    DC motor speed is often regulated with a closed-loop speed controller using tachometer feedback. It is possible, however, to control dc motor speed without tachometer feedback.
  • MTTF, Failrate, Reliability, and Life Testing
    PDF, 51 Кб, Файл опубликован: 4 окт 2000
    At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA547TG3
