Datasheet Texas Instruments DAC108S085CISQX/NOPB — Даташит
СерияDAC108S085
МодельDAC108S085CISQX/NOPB
10-битный восьмеричный цифро-аналоговый преобразователь Micro Power с выходами Rail-to-Rail 16-WQFN от -40 до 125
10-Bit Micro Power OCTAL Digital-to-Analog Converter with Rail-to-Rail Outputs datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 19 мар 2013
Pin16
Package TypeRGH
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY4500
Маркировка108S085
Width (мм)4
Length (мм)4
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Code to Code Glitch(Typ)40 nV-sec
DAC ArchitectureString
DAC Channels8
Gain Error(Max)1 %FSR
INL(Max)2 +/-LSB
InterfaceSPI
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 16 mm2: 4 x 4(WQFN) PKG
Power Consumption(Typ)1.95 mW
Reference: TypeExt
Разрешение10 Bits
Sample / Update Rate2.5 MSPS
Время установления6 µs
Special FeaturesSDO
Zero Code Error(Typ)15 мВ
  • Evaluation Modules & Boards: DAC128S085EVM
    12-bit 8 Channel Digital to Analog Converter Evaluation Module
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
На английском языке: Datasheet Texas Instruments DAC108S085CISQX/NOPB
