Datasheet Texas Instruments TPS79625KTT — Даташит
СерияTPS796
МодельTPS79625KTT
Сверхмалошумящие, с высоким PSRR, быстрые, ВЧ, линейные стабилизаторы с малым падением напряжения, ток 1 А, 5-DDPAK/TO-263 от -40 до 125
TPS796xx Ultralow-Noise, High PSRR, Fast, RF, 1-A Low-Dropout Linear Regulators datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 11 авг 2014
5 предложений от 5 поставщиков
Регуляторы с малым падением напряжения (LDO) High PSRR Fast RF High-Enable 1A
Элитан
TPS79625KTT
507 ₽
TradeElectronics
TPS79625KTT
TPS79625KTT
TPS79625KTT
Pin5
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Width (мм)8.42
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.83
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)1.10 | 1ku
Fixed Output Options(V)1.3
1.8
2.5
2.8
3
3.3
5
Iout(Max)(A)1
Iq(Typ)(mA)0.26
Noise(uVrms)42
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Capacitor TypeCeramic
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)42
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)See datasheet (SON)
Regulated Outputs(#)1
Vdo(Typ)(mV)220
Vin(Max)(V)5.5
Vin(Min)(V)2.7
Vout(Max)(V)5.4
Vout(Min)(V)1.2
RoHSНе совместим
  • Evaluation Modules & Boards: TPS79601DRBEVM
    Evaluation Module for TPS79601 Single Output LDO
  • Evaluation Modules & Boards: TPS78633EVM-207
    TPS78633 Evaluation Module
  • Evaluation Modules & Boards: DEM-SOT223LDO
    DEM-SOT223LDO Compatible with Most Positive Output LDOs in SOT223 (DCQ) Package
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Monotonic, Inrush Current Limited Start-Up for Linear Regulators
    PDF, 268 Кб, Файл опубликован: 22 мар 2004
    The output voltage of a linear regulator tends to rise quickly after it is enabled. This often results in the nonmonotonic rise of the output voltage (i.e., the output voltage overshoots, then dips), which can preclude proper operation of the load circuitry. This application report addresses methods to achieve a monotonic, inrush current limited start-up.
  • Powering today’s multi-rail FPGAs and DSPs, Part 2
    PDF, 307 Кб, Файл опубликован: 18 апр 2006
  • Q1 2010 Issue Analog Applications Journal
    PDF, 2.6 Мб, Файл опубликован: 29 янв 2010
На английском языке: Datasheet Texas Instruments TPS79625KTT
