Datasheet Texas Instruments TS3A26746EYZPR — Даташит
СерияTS3A26746E
МодельTS3A26746EYZPR
Коммутационный переключатель 2 x 2 для аудиоприложений 6-DSBGA от -40 до 85
2 X 2 CROSSPOINT SWITCH FOR AUDIO APPLICATIONS datasheet
PDF, 899 Кб, Версия: C, Файл опубликован: 23 май 2013
Pin6
Package TypeYZP
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка7N
Width (мм).9
Length (мм)1.5
Thickness (мм)2
Pitch (мм).5
Max Height (мм).5
Additional FeaturesManual Microphone Switch Control
Configuration2 X SPDT
Input/Ouput Voltage(Max)3.6 В
Package GroupDSBGA
Ron(Max)0.11 Ohms
Ron(Typ)0.08 Ohms
VCC(Max)3.6 В
VCC(Min)3 В
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3A26746E (1)
  • TS3A26746EYZPR
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments TS3A26746EYZPR
